I have a 2000 sc2 that has a blown engine that I am going to swap out. How difficult is it to go from dohc to sohc? The sohc are cheaper/much easier to find.
You''ll need:
- 1995-2002 SOHC engine - MP2 manual transmission or MP6 automatic (year specific) - Exhaust manifold - Exhaust down pipe - Intake manifold - Fuel rail - Injectors - Throttle cable - A/C brackets - P/S bracket - 2002 SOHC PCM - BCM from the same doner vehicle as the PCM - Instrument cluster Keep in mind that SOHC heads are know to crack when poorly maintained. So you might be buying yourself a whole other set of problems. |
