Cams for SC2
Old May 6, 2011 | 04:15 PM
Sub_Category's Avatar
Default Cams for SC2
Anyone know of any decent hydrolic roller cams for an SC2? I've looked but haven't found much. Don't think SC2's are commonly modified.
Any help would be stellar.
Old May 8, 2011 | 11:01 PM
scdohc2's Avatar
i doubt you'll find any usually its like the 2000's and up years that are modified or its the SL2's. why i dont know, but unfortunately cams from a 2000 sc2 wont fit. 91-99 basically almost every motor part is interchangeable best bet is to either look for more aggressive cams or take the stock ones and clean them up and run on them.2000-and up interchange also but, the sc2 really wasnt meant to be modified because its was for economy which at the time reaching some 36-40mpg was and still is pretty awesome, however theres one or two things you can do without doing a motor swap.
this is a guide, itll tell you everything you need to know bout the parts for sc2 motor
http://www.saturnwiki.net/index.php/Swap_Guide
there really isnt too much for this car, i would say run the stock cams, pick up and o2 sensor with a bypass chip do a cold air intake and a cat back exhaust and run a lightweight flywheel and a stage 2 clutch and your sc2 will just rip. clutch and exhuast will be the most expansive depedning on what you get but the rest can be had for $100 or less.
Old Jul 4, 2011 | 12:49 PM
Sleepy SL's Avatar
http://streetdesignauto.net/ 99-02 DOHC not trying to advertise just trying to help a guy out.
timmerz
Dec 30, 2012 02:09 AM
SilverCoupe#SC2
Engine & Internal
Dec 8, 2012 08:38 AM
weirdkid408
Sep 4, 2011 06:25 PM
mjdjlh2000
Jun 23, 2005 05:38 PM
