Ideas on replacing 2007 ion 3 shifter knob (auto)
Old Feb 18, 2016 | 04:43 PM
mrfreez's Avatar
Default Ideas on replacing 2007 ion 3 shifter **** (auto)
Any ideas/help is greatly appreciated. Heck, I would love to replace/retouch? that whole area.
Attached Thumbnails Ideas on replacing 2007 ion 3 shifter knob (auto)-20160218_160813.jpg
Old Feb 19, 2016 | 09:33 PM
19bonestock88's Avatar
So, I did a little digging...
http://www.andysautosport.com/produc..._PM-2112E.html
These two are compatible with automatic transmissions... Yours comes off by loosening an Allen headed bolt under the chrome trim ring on the bottom...
You could theoretically use any shift **** you wanted, if you held down the plastic rod in the middle of the shifter using the shift **** and tightened the screws in the **** in that position... Know that doing this will effectively disable the "hold brake to shift from park" feature and if you do that, you are solely responsible for any potential negative outcome...
Actually, Summit Racing has a better search, where you can narrow your search results by ***** that have a park release button... Yay!
http://www.summitracing.com/search/p...cending&page=5
Old Feb 20, 2016 | 07:43 PM
what bones said. very curious what is that I supposed to mean. never seen that before. it cant be a 1 cause its above low
Old Feb 20, 2016 | 09:14 PM
mrfreez's Avatar
Thanks bonestock. I did some diggin but was only finding manual shifters. I will check out your links and keep diggin. It looks like mine must have been glued on somehow (see pic). I can see the hex hole, but its not screwed in at the bottom. Not sure how Im gonna fix it. May have to leave it alone for now.
Octavious, I = Intermediate. The manual says, "You might choose INTERMEDIATE (I)
instead of DRIVE (D) when driving on hilly, winding roads and when towing a trailer, so that there is less shifting between gears."
Edit: The pic may be upside down. Sorry about that.
Attached Thumbnails Ideas on replacing 2007 ion 3 shifter knob (auto)-20160220_141104.jpg
Old Oct 9, 2016 | 04:48 PM
tooter1's Avatar
I was wondering how this **** mounted. Thanks.
RjION
Sights N Sounds
Mar 14, 2009 08:10 PM
kcastellucci
Feb 3, 2009 11:47 AM
redcannon
Jun 6, 2007 02:19 AM
trysten
Mar 19, 2007 11:39 PM
deckyrd
Jun 2, 2006 11:05 PM
