i was thinking about getting a stereo system for my car and i was wonder how hard it would be to wire it up because i have never done it before. so i was wonder how hard to would be to wire up amp, speakers, subs, and radio.
Speakers are a simple plug and play. you shouldn't have any problems with the deck either... just find a adapter (Best Buy probably carries it) so the stock radio wiring will plug into the aftermarket CD deck. The amp will take a remote wire from the radio as well as heavy gauge speaker wire from the battery. Then it's just a matter of wiring the amp with the subs. You might want to send a PM to AudioPhyle... he's knowledgeable about the Saturn sound systems. -S-Turn- |
How would I go about taking apart my dash so I can get to the stereo? Does it slide out after removing a few screws under the dashlike a Civicor is everything held on with clips like a Cavalier? I'm used to working with my truck so the Saturn is a new twist to me and it's getting to be a pain in the butt having a busted CD player... And as a side note: Anyone know of a good place to get a filler frame for a single DIN replacement? I know I can go to anywhere and pic one up, but they don't fit right into that curved spot and I've heard that there's ones available that have a pocket that you can put change or whatever under the stereo slot...
