oil usage
Old Apr 21, 2005 | 02:09 PM
romann's Avatar
My 99 sc2 is burnign almost a quart every two weeks. Is this normal for sc2's?
Old Apr 21, 2005 | 11:57 PM
i would say no..do you have very high mileage?
Old May 22, 2005 | 03:05 PM
pawils3's Avatar
I've got a '95 SL2 and always had an oil comsumption problem. Have to add a quart about every 2 weeks also. My teen drives it now and is very hard on it, so I've got to check the oil more frequently.
Old Jun 16, 2005 | 04:45 PM
starless127's Avatar
My 95 does the same thing - more like a quart every 3 weeks (or so). Every time I fill it up, I check the oil levels. Recently, however, I started using synthetic oil and I've noticed slightly less of a consumption. On the lighter side, I've read in other forums that some of the older Saturns are the "Exxon Valdez" of automobiles (obscure reference to the amount of oil wasted).
Old Jun 16, 2005 | 08:57 PM
so no one knows where the oil is going?!
Old Jun 18, 2005 | 03:05 PM
Short of installing a gas chromatograph on my tailpipe, I assume that the oil is being combusted and expelled out as CO2 or some sort of a volitile ketone or ester (there's a sweet smelling odor coming from my exhaust). In my experience, and from everything that I've read about this on Deja.com, Saturn owners experience no noticible dripping.
Old Jul 13, 2005 | 11:42 AM
bam_bam1ca's Avatar
Typical Saturn... check the gas, fill up the oil.
Old Oct 4, 2005 | 04:50 AM
kengine7's Avatar
My 1998 SL-2 burns oil like crazy too. Check the crankcase ventilation blow-by while removing the oil fill with the engine running. If the oil/air/exhaust mixture is very high it may indicate a valve seating problem which may be caused by bad hydraulic lifters. Does your Saturn make alot of engine noise too?
Old Oct 24, 2005 | 02:43 PM
redlined_sc2's Avatar
i have a girl friend with a 96 sc and it does the same thing so take it to the mechanic and see what thee thing do a leak down and compreesiontest umight find it there leaking past the oil ring on the pistons
Old Oct 24, 2005 | 11:54 PM
HeatherP00's Avatar
Theres got to be a leak somewhere....when you step on the gas does any smoke come out??? Is there a odor coming from the exaust???
