A few questions
Old Sep 21, 2010 | 12:37 AM
mattachuz's Avatar
Default A few questions
Hello,
Im going to be purchasing a 2000 saturn LS (im not sure how to tell the difference between the LS , LS1, and LS2) - can you explain that one?
It needs a few things done to it..
1. the intermittent wipers dont work.. the regular wipers work but dont return to the home position when you turn it off so its a fun game of timing it right.
2. the emergency brake cable is snapped because it locked up and couldnt figure how to get it free - dunno if it will lock if i re-install it.
3. the interior door handles are broken? they hang out all the time like the cable is broken? is this a hard fix? and where can i buy parts. i had no luck looking online.
4. the drivers seat cushion is shot or something it sits way deep compared to the passenger seat and pick n pull said its 42 bucks for another one. is this a hard part to put in?
sorry for all the questions but i dont know jack about saturns lol.
Thanks,
Matt
Old Sep 21, 2010 | 06:52 AM
1. Lemmie look in my book, and I'll get back to you on this.
2.
3. Go to local GM dealer that might have sucked up a closing Saturn dealership
4. Not difficult, but you're gonna need to buy a Manual for you car to proceed
Old Sep 21, 2010 | 11:17 AM
mattachuz's Avatar
thanks for the reply, i looked about the wipers alot on my own and the only thing i got replies on was the whole wiper motor needed replacing because it had an intermittent board inside?
also the drivers seat isnt powered so i figured it would just be 4 post bolts to get it out unless saturn does something "cool"
the handles i was looking more to get a OEM kit, but i was also looking at pick n pull, if i can get the door apart (goodluck) its 12.99 a side.
Old Sep 22, 2010 | 05:00 PM
mattachuz's Avatar
2.
did you find anything?
also whats the difference between the LS and LS1?
Old Oct 16, 2010 | 05:47 PM
Standard equipment like power windows, and if we can take the time to look everything up so can you.
Old Oct 17, 2010 | 08:55 AM
Matt --
With respect to your intermittant wipers, it's most likely a defective connection in the wiring at the wiper module, however, it could also be a bad control switch in the steering column. I'm assuming you have purchased a Haynes/Chilton manual by now -- break out the meter, and start tracing the circuit .........
Old Oct 30, 2010 | 10:44 PM
mattachuz's Avatar
Matt --
well i actually got a saturn specialist mechanic that im going to have do the work. I have to get my rear drums repaired monday because one will howl on right turns.
m&m1026
Feb 20, 2016 07:52 AM
countryrocker18
Aug 16, 2011 09:05 AM
winkler91
May 20, 2011 12:07 AM
saturnsdn
Dec 29, 2009 03:17 AM
Dogberri
Aug 19, 2009 10:19 AM
