reverse
Old May 23, 2006 | 06:35 PM
2DOLLAR's Avatar
hey has anyone tried tighting the reverse nut in the tranny to make it stop slipping like ottjoe talks about ?if so did it work ? and how hard is it to do?
Old May 25, 2006 | 01:00 AM
It works if thats what the problem is. If its the valve body then it will not work.
Old May 25, 2006 | 06:29 PM
2DOLLAR's Avatar
Its not my valve body I changed it already .how hard is it to tightin this bolt?
Old May 27, 2006 | 12:19 AM
First it is not called the reverse nut.
You need to replace and tighten the input and output shaft nut. When a bad valve body is left unattended the shaft nut will come loose.
Just a start you do need a tool to keep the shaft itself from turning so the nut can be tightened.
1-Jack the car up as high as possible or use a lift
2-Remove the left front tire.
3-Remove the plastic panal that covers the transmission end cover.
4-Remove the front brake hose mount. Do Not disconnect the end of the brake hose.
5-Remove the transmission cover nuts. Pull the trans end cover out about eight inch's without bending the tubes.
6-With a 21mm socket and the special tool needed to hold shaft in place remove one nut.
7-Replace old nut with a new one and tighten with the same socket and tool
8-Remove the second nut and replace the same way.
9-If your in over your head. Take to the dealer.
Old May 27, 2006 | 07:47 PM
2DOLLAR's Avatar
where can I get this tool to hold the shaft from turning?
Old May 29, 2006 | 03:10 AM
ram440sb's Avatar
SW2 where is your helpful answer to this members question?
Old May 29, 2006 | 11:01 PM
2Dollar..................You can get the tool here http://www.spxkentmoore.com/ and you can also check e-bay. I have seen many Kent Moore tools listed.
Old Jun 2, 2006 | 01:22 AM
2 Dollar................make that a 23mm socket.
Old Jun 2, 2006 | 01:25 AM
RamRamRam...........your retention is getting worse. You must be counting sheep.Edited by: sw2cam
ozer
May 4, 2006 01:03 PM
gomoose
May 4, 2006 01:48 AM
rtrimarc
May 1, 2006 12:45 PM
mellen823
Jan 17, 2006 01:22 AM
dannyy72
Oct 17, 2005 02:56 AM
