2002 Saturn L300 Starting
Old May 16, 2006 | 09:11 AM
deanrp's Avatar
I come out of the house and the car starts fine. If I drive a couple of miles and stop the car it will not start. The engine turns but will not start. If I spray starting fluid in the air cleaner the car will start and run fine. It seems to be intermittent because yesterday I had no problems. I never seem to have a problem when the unit is cold but only when I drive it a couple of miles and shut it off.
Old Jun 1, 2006 | 02:55 PM
Dean.....................are you getting a SES light by any chance?
Old Jun 1, 2006 | 03:00 PM
deanrp's Avatar
I found the problem - The crank sensor was breaking down when the engine got warm. I had an error code for the speed sensor andon the third day the auto would stall at a stop sign. The crank sensor fixed everything.
Old Jun 1, 2006 | 03:30 PM
Outstanding..................happy you found the problem. A throttle postion sensor can cause the same sort of thing. So if it happens to you in the future you have a couple of things to look at.
Old Jun 2, 2006 | 04:31 PM
deanrp's Avatar
Saturn is having problems with the crank sensor.
Old Jun 2, 2006 | 11:16 PM
No more than any other car on the road.............Parts fail.
rogers
Nov 25, 2014 12:53 PM
chblanx
Jun 7, 2012 05:11 PM
MLC1990
Mar 6, 2011 01:16 PM
jsdub525
Aug 27, 2008 04:39 PM
mpl1954
Saturn L300
Jul 6, 2008 09:06 PM
