shift problem
Old Aug 29, 2009 | 05:52 PM
AnnieAngel's Avatar
Default shift problem
my 2002 saturn won't shift. Any ideas?
Old Aug 29, 2009 | 06:41 PM
2002 SATURN
VUE
L-Series
S-Series
Auto trans
Manual trans
What the heck, I'm guessing your a female, but just a bit more info is need then what you provided. We don't care what color the car is or the color your nails.
Old Aug 30, 2009 | 01:02 AM
AnnieAngel's Avatar
It's a 1999 SL2. Basically it just feels like there's nothing to shift into now because the stick moves in all directions with almost no resistance. It happened suddenly. I was pulling out of a parking lot in 1st and then went to shift into 2nd and there was nothing there. I suddenly found myself in neutral with no power. I pulled over and thought that it was a lost cause but then I moved the stick far forward and I was finally able to catch a high gear; maybe 3rd. I made it home, somehow making most stop lights with a little timing, but had to stop once and barely got the car moving again in that higher gear.
Old Aug 30, 2009 | 03:37 AM
saturnsdn's Avatar
sounds like the shifter bushing went out which seems to be a common issue with the s-series.
your best option would be to get this one
http://cgi.ebay.com/ebaymotors/Stain...Q5fAccessories
but any of these will work
http://shop.ebay.com/i.html?_nkw=shi...82&Make=Saturn
Old Aug 30, 2009 | 06:43 AM
Indeed, sounds like shifter bushing failure.
I used the stainless one from the first link above and have been quite happy with the results.
You will know for sure when you remove the center console (< 6 screws, a switch popout, and a bulb removal.
While waiting for parts:You can reseat the shifter cable end over the end of the shifter and secure with zip ties applied in an "X" pattern. Just test it in the driveway before you go out on the road, and shift gently.
Old Aug 30, 2009 | 09:06 AM
AnnieAngel's Avatar
Thank you, sooooooo much. I am very familiar with all the Corvette forums, I belong to, and wondered if just maybe, there would be a Saturn Forum and if I could get any help on it. Well, I found it, you helped me and I am so thankful. Last but not least, how much should I expect to pay for this type of repair?
Again, thank you!
Old Aug 30, 2009 | 01:55 PM
So I take it your SL is a 5 speed manual transmission, if so go to your nearest SATURN retailer and buy a set of shift cables. Fix it right fix it once .......
Old Aug 30, 2009 | 02:44 PM
AnnieAngel's Avatar
thank you, you guys are the BEST!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 4, 2009 | 01:59 PM
AnnieAngel's Avatar
Turned out to be the cable. Repair job $400.00+ :-(
Thanks for all your help, however.
Old Sep 5, 2009 | 07:02 PM
We told you what was wrong not what it cost to repair.....sorry.
CALegalVette
Sep 4, 2007 07:34 AM
trysten
Mar 19, 2007 11:39 PM
pop_fly
Mar 4, 2007 09:10 PM
deckyrd
Jun 2, 2006 11:05 PM
Rocky
Feb 14, 2006 05:06 PM
