Suspension Talk about your suspension within...
Erratic steering when braking, need opinion
Old Aug 5, 2009 | 10:43 PM
Jonnysig's Avatar
Default Erratic steering when braking, need opinion
Hey guys,
I got a 97 Saturn SL1 4DR Sedan. I keep her running good and do all the maintenance myself. But I must confess that I do not hold the knowledge to troubleshoot or make a call on this issue. When I apply pressure to the brakes at any speed over 30mph (especially down hill) I get erratic steering and the car shakes.
So i've got my head burried in my Haynes manual and the troubleshooting tree gives me these four possibilities....
1. Front hub bearings worn
2. Broken or sagging springs
3. Leaking wheel cylinder or caliper
4. Warped discs or drums
I have enough knowledge to know that theres no leak coming from the calipers but the other 3 I am unsure of. I can handle working on the brakes myself but springs and hubs??? Anyone got any info or has anyone heard of this problem. Anyway to pinpoint or isolate one of these problems??? Thanks guys! Hope someone can help.
John Signorelli
Old Aug 6, 2009 | 09:41 PM
Front brake ROTORS are warped ... it's common to ALL cars as milk is to a dairy.
Old Aug 30, 2009 | 01:00 AM
saturnsdn's Avatar
agree with Rj do something about the rotors and the issue should be solved
Old Aug 31, 2009 | 11:33 PM
Jonnysig's Avatar
Are rotors something I can get fixed or does warped mean theyre toast...should I just replace them???
Old Sep 1, 2009 | 12:04 AM
saturnsdn's Avatar
call near by parts stores and see if they machine rotors. they should measure them out and see if they are thick enough to machine and remain within specs before they do anything otherwise you'll have to replace them
Old Sep 1, 2009 | 05:52 AM
and if you replace them you'll want to consider replacing pads as well if they show signs of uneven wear
Old Sep 6, 2009 | 12:23 PM
Yes ................ replace the brake pads at the same time.
Old Sep 6, 2009 | 09:48 PM
Well, let me jump in here too, and suggest that you bypass the thought about re-machining the rotors, and simply replace them.
Rationale:
Saturn OEM rotors are easily warped. Machining them to return them to smooth condition removes a portion of the original thickness, causing them to overheat easier in the future, with the result of additional warpage. Save time/grief/grey hairs by replacing the rotors this time
Old Sep 7, 2009 | 05:54 PM
Smile
Rationale:
OceanArcher owns the company that builds aftermarket rotors .... LOL
Old Sep 7, 2009 | 08:06 PM
Default Re: Second Career
LOL -- I wish SW2cam was right, but sadly, that is not the case. I have, however, attempted to have Saturn rotors turned before, and they just don't remain true
