clutch replacement
Old Nov 10, 2005 | 02:53 PM
sl2intexas's Avatar
Hi All,
Has anyone changed a clutch in a 1997 SL2? Are we talking a major league PIA? Any suggestions or helpful hints. I'm asking because my mechanic is quoting me over $1000. I'm pretty mechanically inclined and have done major work on other cars, just not a clutch in a FWD car.
Thanks in advance,
Richard
Old Dec 14, 2005 | 05:57 PM
Tbone's Avatar
Hey Richard,
I can't give you any pointers right now. I can tell you I am in the same boat. I have a brand new clutch etc. to put in this weekend. I will let you know how it went. I have a 1998 SL. Wish me luck.
Terry
Old Jan 13, 2006 | 01:39 PM
SL2Tim's Avatar
All I can say is the only difference with front wheel drive is the removal the left suspension so that you have room to work. Otherwise it no more difficult than a rear wheel drive.
Old Feb 6, 2006 | 09:01 PM
Collins's Avatar
changing the clutch isn't a big job. I'm after changing the transmission a few times on my car. just unbolt it clean from the engine, and the mount above and below the transmission on the left side, and instead of removing the suspension, pop out the ball joint and pull out the side axle. if you can haul the transmission back far enough. you will be able to get at the clutch easier. (may have to remove shift linkage from transmission too)
Hope this helps
Old Feb 27, 2006 | 12:50 AM
explicitcivic's Avatar
Hope this helps
+1 on removing shift linkage, makes work a lot easier
Old Mar 12, 2006 | 02:04 AM
euroc's Avatar
1000$$$??? Some mechs are rediculous!
prophetnite
May 12, 2008 11:34 AM
2000saturnsl2
Mar 16, 2008 04:28 PM
johngooden
Dec 10, 2007 09:08 AM
caoiii
May 25, 2007 11:44 AM
david e
Nov 6, 2006 10:32 PM
