1999 SL1 High Pitched Whine
Old Oct 6, 2005 | 01:02 AM
earthrnangl's Avatar
I have a 1999 SL1 which is making ahigh pitch almost wind up key noise henever I accelerate. Anyone know what could be causing this or better yet how I can fix it. Thanks.
Old Oct 6, 2005 | 04:44 AM
desperado's Avatar
the last time i encountered a problem of that sort, a new fan belt replacement did the whole trick.
Old Oct 6, 2005 | 08:03 PM
Thanks. I'll give it a try.
Old Oct 17, 2005 | 02:48 AM
rick_ryder's Avatar
If the noise goes up and down with enging rpm it's probably the alternator on its way out. If it's not a squeel? when the bearings start to go in the altthey make a good whinnnig sound. There is another bearing on the idler pully, located right below the top mount, that can cause a whine also when it time is almost up.The alt should be putting out about 96 amps under load so if you get it tested at a shop and the say its look ok make sure the amperage is in the high 80 at least. when the bearings start to go the alt usually puts out about 60-70 amp ok for some cars but not for saturns.
helistructor
Nov 14, 2010 07:16 PM
Sage927
Nov 7, 2010 05:03 PM
Larissa72
Jan 19, 2008 07:36 PM
Benjiboy_01
Feb 13, 2007 04:31 PM
blind527
Nov 22, 2006 09:33 PM
