Saturn Won't Start Normally-Spark Plugs Carbon Fouled
Old 06-07-2016, 07:59 PM
Banson's Avatar
Default Saturn Won't Start Normally-Spark Plugs Carbon Fouled
I have a 92 Saturn SLI. It won't start normally. The engine doesn't turn over when turning the key. If I hold down the gas pedal why turning the key I can get it to a very hard start. I have to hold the gas down for a few seconds and then rev the engine a little, black smoke comes out the back, but I can get it going. However, when I stop the engine stalls. And I would have to go through the same process to try to get it to run again.
I pulled the spark plugs and they looked carbon fouled. I replaced the spark plugs and the car started normally and ran alright for about 20 miles and then when I stopped at a red light it stalled out again and I had to go through t the same rough start process again and keep fighting it at every stop.
Is there a likely suspect for this situation? Someone suggested that the car is running rich and it might be the fuel pressure. Does that sound likely?
Old 06-08-2016, 07:02 AM
Have you ever replaced the ECTS? If not, DON'T get one from Autozone, Advance, O'Reilly, etc. Find a Saturn friendly GM dealership and get it from them, along with the pigtail. But first, check the connector to yours. It's a simple squeeze type and after purchasing the ECTS and pig tail for one of mine, I discovered that the pig tail was all I needed because the connector was broken. Solder the connector and shrink wrap it. Don't half *** it with a wire nut and electrical tape, like I've seen some idiots do.
Old 06-08-2016, 09:56 AM
I agree, sounds like a classic GM coolant temp sensor failure. This is a common failure on fuel injected GM cars. Each manufacturer has their own common problems.
petes343434
02-15-2020 10:51 AM
Warlik50
Saturn L300
19
01-18-2019 08:20 AM
Pop13
01-15-2013 04:36 PM
daysu47
07-17-2008 09:21 AM
hierophant
08-31-2006 01:21 AM
Quick Reply: Saturn Won't Start Normally-Spark Plugs Carbon Fouled
