Reverse gear and transmission problem
Old 11-07-2005, 07:53 PM
ozer's Avatar
Hi
I have 1992 Saturn SL-2. Car runs and drive fine. B Ut when I try to reverse, it has hard time to engage. It takes about 5 second to engage it. When it is engage it is really harsh. Car, shakes, make a loud noise and engage it. If I touch the gas pedal, it engage quickly but harsher. And most of the time, car stalls.
Someone told me that it may be the clutch in tranny or valve body. Anyone had similar problems or any idea.
thanks
ozer
Old 11-08-2005, 01:12 AM
ottjoe88's Avatar
automatic or manuel? If automatic the bolt that holds the reverse planetary needs to be tightened. I will send you a picture if you want
Old 11-08-2005, 03:38 PM
Patrick's Avatar
Administrator
it seems like an automatic to me...
Old 11-08-2005, 07:22 PM
ozer's Avatar
it Is AT. Yes I will need the picture. thanks
ozer@u.arizona.edu
Old 11-09-2005, 08:33 PM
Tarl's Avatar
Could I get a copy of the picture also, I'm having the same problem
Old 11-09-2005, 09:13 PM
dannyy72's Avatar
i wouldn't mind getting the picture as well, thanks a million.
dannyy72@hotmail.com
Old 11-30-2005, 05:06 PM
ottjoe88's Avatar
i will get them to you asap. You will need access to a 1/2 in. drive air impact, a set of jack stands, a good set of sockets, a floor jack and a cheap 15/16 1/2 in drive deep socket that needs to be ground down
Old 05-03-2006, 08:51 PM
Red94's Avatar
Hello OTTJOE88
I am having reverse troubles as well. Could you send me your photos and any info that may help me with this problem?I appreciate the help!
Thanks
Old 05-04-2006, 01:03 PM
2DOLLAR's Avatar
PLEASE SEND ME PICS ALSO I HAVE ALREADY CHANGED THE VALVE BODY AND IT STILL WILL NOT PULL IN REV.THANK YOU FOR ANY HELP YOU CAN SEND MY WAY cwalker2@charter.net thanks agian!!!!!!!!!!!!!
AConsciousEarth
04-30-2013 09:20 AM
jizake1jz
08-03-2008 09:46 PM
jeffwallner
08-03-2008 07:07 PM
gomoose
05-04-2006 01:48 AM
rtrimarc
05-01-2006 12:45 PM
Quick Reply: Reverse gear and transmission problem
