What happened to my post??
Old 08-31-2008, 08:53 PM
mrpackrat's Avatar
I posted earlier today for help on a 97 sl2 that is driving me crazy, and now my post is no where to be found in any section-what happened??
Old 08-31-2008, 09:55 PM
mrpackrat's Avatar
Hello all, I have a 97 sl2 with 1.9 dohc, and it has a major problem
right now. When cold it will start right up and run good, but to start
it you must hold the throttle to the floor, and when it warms up if you
shut it off it will not start back up. It will try if you hold the
throttle to the floor-what it does after cranking for about 5-10
seconds is starts for a split second revs to like 1500 and the dies
immediately. I have replaced the spark plugs, fuel pressure regulator,
ignition module, map sensor, disconnected the battery to reset, new air
filter, pvc, and probably more. Only things I have not replaced are
tps, crank angle, computer and oxygen sensor....Any ideas?? Please!!
Oh yes I did a block off plate for the egr_but still left the
electrical connector hooked up-no check engine light either...The egr
is the first thing I did.. Oh yes when it does start up it is running
RICH-black smoke coming out of the exhaust, and stutters like it is
choked and then it slowly comes around and revs up and clears out, I
also disconnected the charcoal canister...I just thought of something
else, the temp gauge does not work-stays on cold all the time. i wonder
if it could be the sending unit telling the computer that the engine
is cold and injecting extra gas-like the choke on????
Old 08-31-2008, 11:06 PM
If you posted it in the New Member Area ... I deleted it.
Edited by: sw2cam
Old 08-31-2008, 11:11 PM
mrpackrat's Avatar
No it was in this section..general tech help...
Old 08-31-2008, 11:19 PM
No idea ...
IP Address 72.191.51.240
City NEW PORT RICHEY
State or Region FLORIDA
Country UNITED STATES
ISP ROAD RUNNER HOLDCO LLC.
Is that close to san antonio texas
Edited by: sw2cam
Old 09-01-2008, 12:18 AM
mrpackrat's Avatar
I am in sa texas, I have no idea what that new port richey is about....
Old 09-01-2008, 09:58 AM
mrpackrat's Avatar
I think I have it figured out. The coolant temp sender is saying the engine is -8 degree celcius when it is about 80 degrees outside. I unplugged it and the car starts right up and runs great-just check engine light is on now..Got the new sensor going to be here in a couple hours...
Old 09-01-2008, 01:34 PM
mrpackrat's Avatar
FYI it was the coolant sending unit-replaced it the gauge works the engine starts beautifully cold or hot and runs and drives great...
Old 09-01-2008, 06:28 PM
Celcius you say .........
Old 09-01-2008, 06:45 PM
mrpackrat's Avatar
correct-with my nemisys obdll tester-that is what it read-like below freezing even when it was 100 degrees F here...
Quick Reply: What happened to my post??
