2001 sl2 no start condition
Old 04-07-2011, 02:53 PM
john doe's Avatar
Default 2001 sl2 no start condition
working on my neighbors car .a 2001 sl2 .it has a no start condition .once and awhile it will start .
today during the no start i tried putting my code reader on it (obd-II)the reader would not even power up .
so right away i,m thinking ,bad computer.
what you think??/the code reader should start right up when i plug it in .
just so you know i cleaned all the fuses related to computer operation,the comp ground as well.
is there anything else i should be checking ?fusible link?a fuse i overlooked?
i could not get it started .
but she can every once and awhile .like maybe after it sits awhile.it started once today but she shut it off befor i could test the reader on it .then we couldnt get it going again .
any help??
Old 04-07-2011, 03:23 PM
john doe's Avatar
update .....got it started but still nothing from the obd-II connector .which is strange in itself .how is this thing running with no computer support?
Old 04-07-2011, 04:01 PM
john doe's Avatar
ok, google got me the answer and we now have the port working .
got a p1599 code now.
Old 04-07-2011, 08:49 PM
just means engine stalled while running.
Does it crank with no start or is there no cranking with no start?
Old 04-08-2011, 12:44 PM
john doe's Avatar
update ...changed the crank position sensor after much reading on google searches .didnt help .
the car cranks fine ,if you put the gas to the floor it will sometimes start .has stalling issues .almost like its not getting gas .took it for a ride and it has power but nearly sputtered out and died on me .made it back and it died.
still got wires to put on but its raining pretty good now .
Old 04-08-2011, 12:55 PM
Sounds like the ECTS and associated connector need to be replaced. Cost is about $40 usd, and a couple of hours of your time. Be sure to use Teflon tape on the threads of the new sensor, and be sure the sensor is the one with a metal tip. Resin tipped sensors are not robust, and go bad quickly ...
Old 04-08-2011, 12:58 PM
john doe's Avatar
ects???couple hours?wheres this located?
Old 04-08-2011, 02:30 PM
ECTS -- Engine Coolant Temperature Sensor
A two-wire sensor located on the driver's side of the engine just below the thermostat housing
Old 04-08-2011, 06:04 PM
john doe's Avatar
and that little item can cause stalling?puttering?
it doesnt throw a code either??
out of curiosity i went out and unplugged it .the car did start but the idle was very erratic.
Old 04-08-2011, 06:57 PM
That "little item" adjusts the air/fuel mixture ratio of the engine via the computer. It does this for maximum fuel efficiency. It is an active device, but often will not throw a code
Quick Reply: 2001 sl2 no start condition
