-   Tires (https://www.saturnforum.com/forum/tires-20/)
-   -   need new rims and wheels (https://www.saturnforum.com/forum/tires-20/need-new-rims-wheels-3765/)
abmontalbo1119 Sep 13, 2009 04:05 AM
suggestions
derf Sep 13, 2009 06:30 AM
Most wheels with a 4 x 100 bolt pattern will work. I have stock alloy wheels on my SC2s so I do not know which aftermarket brands fit without hub issues.
Rj -- any advice?
RjION Sep 13, 2009 12:57 PM
Go here and punch in your info
http://www.discounttiredirect.com/di...cid=spotlight3
sw2cam Sep 13, 2009 03:04 PM
Damn that would be to easy to do.
abmontalbo1119 Sep 13, 2009 03:47 PM
thanks guys. whats the biggest size you think i could go before it looks bad
sw2cam Sep 13, 2009 06:09 PM
What do you drive ........... a Yugo or a Nogo?
carterseth32 Sep 13, 2009 10:24 PM
I have 17" by 7' Konig feathers on my 2001 sc2. Pics on my prfile..
abmontalbo1119 Sep 14, 2009 02:06 PM
thanks man appreciate it
saturnsdn Sep 15, 2009 01:46 PM
to me it all depends on what you like not what others like. some stay with the same size cause they don't like changing size. others do the biggest they can get away with while others do in between.
I've seen a newer sl running around here running bigger rims that may not look so bad if it didn't cause the car to sit so high. Its high enough it literally makes my car look dropped and its not.
98sc1gold Sep 15, 2009 04:08 PM
decide what look you want... conservative, chrome, racer, etc. and go for it. make sure you dont get such a big rim that the tires sidewall is so small that one pothole will bend your rim, unless you are lucky enough to traverse smooth, well maintained roads. also, huge, heavy rims are extra unsprung weight which may compromise performance, so go lightweight. btw- what year, model?
