spring rates and coilovers
Spring Rates:
OEM Springs: ............................ 126 lb/in Front, 129 lb/in Rear H&R Race (1.4"F, 1.3"R):.............. 310 lb/in Front, 250 lb/in Rear H&R Sport (1.4"F, 1.3"R):............. 205 lb/in Front, 195 lb/in Rear Eibach Pro Kit (1.3"F, 1.1"R):........ 149 lb/in Front, 91-159 lb/in Rear Progress Group (1.8"):................. 200 lb/in Front, 170 lb/in Rear Progress Group (1.3"):................. 156 lb/in Front, 150 lb/in Rear Sprint (2.0"):............................. 200 lb/in Front, 140 lb/in Rear Sprint Extreme(2.5"): .................. 200 lb/in Front, 140 lb/in Rear Suspension Techniques (1.4"):...... 157 lb/in Front, 109-155 lb/in Rear Struts: KYB GR-2 front: 30% stiffer than stock KYB GR-2 rear: same as stock Agility Coilover - Saturn S-Series - 1991-2002
COILOVERS Product Name 8-Way Rebound Adjustable Coilovers http://www.amrengineering.com/assets...ls/spacing.gif Brand AMR Engineering http://www.amrengineering.com/assets...ls/spacing.gif Description Assembled here in the USA, our custom coilover systems are designed to meet your needs. Our coilovers feature a mono-tube design, and machined using the latest tooling and equipment. Our machine work is simply outstanding, and we take great pride in the quality of our work. These are available rebound adjustable only and feature a distinct 8 click design. Our coilovers also allow you to adjust both preload and shock length. So adjusting both ride height and preload is fast, and simple. With the ability to adjust shock length you maintain your shock travel, and lower your car without sacrificing too much ride quality. Our saturn coilovers are the only ones available with front and rear camber plates. These also include spherical bearings in each corner. These are meant to be the last coilovers you will ever need for your vehicle and come with a lifetime warranty on both the shock and spring. Speak to us today about getting a set made specifically for you and your driving needs. No more guessing games, leave it to us, and we guarentee you will love the ride quality and performance of our product. I AM NOT A VENDOR FOR ANY OF THESE PRODUCTS just some good inf o if someone didnt know figured I would contribute a possible sticky |
Good post, keep them coming. Post ION info also.
| All times are GMT -5. The time now is 01:09 AM. |
