-   Suspension (https://www.saturnforum.com/forum/suspension-19/)
-   -   Clunking Noise following suspension work (https://www.saturnforum.com/forum/suspension-19/clunking-noise-following-suspensin-work-2902/)
derf Jul 21, 2009 06:06 AM
Clunking finally resolved
Well, folks, the clunking was traced to undertorqued cradle-to-control-arm fastener. I remember tightening the crap out of these and rechecking them after alignment and finding them tight, but apparently they were not torqued all the way to spec and as a result the control arm end was shifting around.
I did not have a torque wrench that could fit in that tight of an area....my bad.
Yet another demonstration of why adhering to torque specs is so important....
OceanArcher Jul 21, 2009 07:38 AM
So glad you were finally able to track down your gremblin ... ride well, Dude
RjION Jul 25, 2009 10:07 PM
Well derf..........it's about time you fixed it.
derf Jul 25, 2009 11:50 PM
a week off from work gives you time to fix alot of stuff
My A/C now works too
OceanArcher Jul 26, 2009 10:39 AM
Ohhhhhh -- Now Derf's got a coool ride also ...
derf Jul 26, 2009 11:00 AM
turned out to be low side/service port was the only leak -- compressor was fine...
OceanArcher Jul 26, 2009 04:30 PM
Great -- sometimes its the little things that get ya. Inexpensive fixes are perks of the Forum
Ed Peterson Jul 17, 2018 07:52 PM
How
How much did it cost to fix and what does it take to do it
derf Jul 18, 2018 05:23 AM
It cost me my tme, some 1/2 in metric sockets n wrenchi (already had), and someone stronger than I to torque it down. Might have helped to use new bolt and nut.
In retrospect, having worked on my other s car suspension, I actually needed to replace the front sway bar bushings and bolts. When they wear, thr whole stabilizer bar moves forward. Add that to the angled geometry of trying to get the stabilizer bar end through the control arm with enough play to get the control arm lined up in the cradle slot. With the stab bar too far forward it is eventually not possible.
