Suspension Talk about your suspension within...
Clunking Noise following suspension work
Old 07-21-2009, 06:06 AM
Default Clunking finally resolved
Well, folks, the clunking was traced to undertorqued cradle-to-control-arm fastener. I remember tightening the crap out of these and rechecking them after alignment and finding them tight, but apparently they were not torqued all the way to spec and as a result the control arm end was shifting around.
I did not have a torque wrench that could fit in that tight of an area....my bad.
Yet another demonstration of why adhering to torque specs is so important....
Old 07-21-2009, 07:38 AM
So glad you were finally able to track down your gremblin ... ride well, Dude
Old 07-25-2009, 10:07 PM
Well derf..........it's about time you fixed it.
Old 07-25-2009, 11:50 PM
a week off from work gives you time to fix alot of stuff
My A/C now works too
Old 07-26-2009, 10:39 AM
Ohhhhhh -- Now Derf's got a coool ride also ...
Old 07-26-2009, 11:00 AM
turned out to be low side/service port was the only leak -- compressor was fine...
Old 07-26-2009, 04:30 PM
Great -- sometimes its the little things that get ya. Inexpensive fixes are perks of the Forum
Old 07-17-2018, 07:52 PM
Ed Peterson's Avatar
Default How
How much did it cost to fix and what does it take to do it
Old 07-18-2018, 05:23 AM
It cost me my tme, some 1/2 in metric sockets n wrenchi (already had), and someone stronger than I to torque it down. Might have helped to use new bolt and nut.
In retrospect, having worked on my other s car suspension, I actually needed to replace the front sway bar bushings and bolts. When they wear, thr whole stabilizer bar moves forward. Add that to the angled geometry of trying to get the stabilizer bar end through the control arm with enough play to get the control arm lined up in the cradle slot. With the stab bar too far forward it is eventually not possible.
Alejandro Rivera
08-30-2018 11:01 AM
spasm3
05-22-2015 03:27 AM
gpeterson
01-06-2015 12:10 PM
tealsc1
12-17-2008 10:57 PM
garyb
07-02-2007 12:29 AM
Quick Reply: Clunking Noise following suspension work
