-   -   Timing belt replacement (https://www.saturnforum.com/forum/saturn-vue-24/timing-belt-replacement-9437/)
kzdcz3 Mar 21, 2014 05:31 AM
It's time to replace the timing belt in 2004 Vue with Honda 3.5 V6. Is there any good brand that I should buy? My car does not leak oil, should I replace the cam/crank seals? Thanks,
Rubehayseed Mar 21, 2014 07:32 AM
I don't know the replacement recommendation, but if you do it, you'd better replace the water pump too. It's driven by the timing belt and you don't want to have to go back an do stuff over again. Just replace all of the stuff while you're in there and be done with it. I THINK it's around 100,000 t0 105,000 miles.
