starter removal 2003 vye V6 AWD=???
How do i access the starter on this v6 awd car? Point me to a procedure.I actually am trying to replace the Crank shaft sensor-its located?? close to the starter. yet after crawling under the car I cant even see the starter. Help Please.
Here's a youtube video showing how to replace the CPS.
starter access?
Thanx for the video- i have seen one this man previously posted. didnt show starter removal at all. What it doesnt explain is = As I have just looked under this car-Im still curious as to what wheel?? lt or rt. to remove & appears theres also a panel that must be removed to gain access to this area? I know the starter must be on the firewall side of engine . Appears the drivers side wheel & any associated panel behind it needs removal? Thanx
1 Attachment(s)
See attached thumbnail, #6 is the CKP (Crank Position Sensor)
Note Big Arrow pointing towards front of car. This CKP is mounted betw the front fender and the crank, not betw the firewall and the crank. If this is not your engine, then continue searching the net as I did. |
Nice find, derf! They really tucked the starter in there on that V-6, didn't they? Anyway, Twinpilot, you have your answer. I'd suggest some good jack stands and a bright light under the car so you can see what's what.
Thanx to all !!
Slid under the car again last eve. Found the starter!! Wholly Cow- i need arms the size of a spagetti noodle to get to that one. Now - going to a shop with a lift!! Thanx to all for the input!!
Yep, it's pretty obvious that a lot of automtovie engineers NEVER work on their own vehicles, isn't it?
Thanx to all- Got the crank pos changed -still same problem-posting again. Again Thanx
Where'd you get that sensor? I sure hope it was from a GM dealer and not a chain store like Autozone. If so, you got what you paid for. A cheap sensor that's not within the proper parameters for the Saturn engine. I NEVER buy sensors anywhere except from a dealer. At least that that I'm getting OEM parts. Sometimes aftermarket parts are NOT such a bargain.
Bought sensor from NAPA - Id hate to get dealer pricing!! The car actually acts up (quits) at different mileages now.??Since cps replaced. Im still leaning to computer bad since everything shuts off - even fuel pump=just like key turned off!
