Saturn vue awd engine swaps
Old Nov 6, 2019 | 11:16 PM
Michael Bond's Avatar
Default Saturn vue awd engine swaps
I was wondering if there are any available engine swaps for a 2009 Saturn vue that's an all wheel drive it
Old Nov 10, 2019 | 11:04 PM
Since we don't know which Vue you have, the answer to your question is that, yes oh, there are two engines that you can swap in. They are two of the three offered engines that you do not already have. Hope this
Old Jan 15, 2021 | 07:12 PM
Thumper Simpson's Avatar
It's got the same GM engine used in Malibu and Impala, so any versioon should work including a 4.3 out of a GM front wheel drive.
Old Jan 16, 2021 | 10:10 PM
Interesting.
2009 Vue XR AWD comes with 3.6 V6 only
2009 Vue XE AWD comes with 3.5 V6 only
So I fear your response is on average only 50% correct. I think it was the 3.6 that is shared across the GM line not the 3.5.
4.3? How would we know? Would the Vue PCM be able to control it? Do you flash it as a different vehicle that has a 4.3 in it? I doubt there's an option for it that you could flash the PCM with as a Vue.
Old Jan 16, 2021 | 10:21 PM
being a long-time hot rodder and car builder, I can assure you that the 3.5 is a pushrod cross-platform motor, also sold to other brands. The 3,6 is a more modern and fuel efficient motor, and is the basis for what is now the 335hp LGX motor in my Camaro.
Old Jan 16, 2021 | 10:26 PM
The most obvious difference in the 3.5 and the 3.6 is that the 3.5 is a pushrod engine and the 3.6 is DOHC.
Old Jan 17, 2021 | 08:05 AM
Thanks for that
charlescjensen
Feb 9, 2020 10:22 PM
rperkins_911
May 13, 2018 10:30 AM
beckers
Jul 29, 2013 10:20 AM
usedvueman
Nov 16, 2008 04:06 PM
judov79
Nov 29, 2007 07:15 PM
