Relay/fuse box plug question
does anyone know how to read the plugs under the under hood relay/fuse box on a Saturn Vue. I have a 2004 Saturn Vue and am trying to locate certain pins on certain plugs but have no idea which plug is the A, B or C plug or how to identify the number of the pin / receptacle within those plugs. The first pin I am trying to locate is C3 - F9.
Thanks, Andy |
You may be able to locate that info on the net or maybe you tube.
Ended up not needing for the CVT conversion to 5 speed since the relay box wiring is the same. Only difference is the wiring harness and the engine ECM.
Thanks, Andy |
