The odometer on my 2005 VUE no longer lights up. Blown fuse ???
Is it just the light that illuminates the odometer or all the lights that illuminate the entire cluster that are out?
Just the light that illuminates the odometer.
Help. |
The bulb is replaceable need to remove the cluster.Most likley need to get the bulb from the dealer.
Easy fix - dead bulb - bulb is $ 8.00 at the dealer...Remove IP trim - 2 screws on top & pull straight outRemove 4 hex head screws on 4 sides of IP - pull IP straight out.Remove odometer bulb - its the white one close to the bottom - remove it by turning it 1/4" counter clockwise Replace bulb...Install is reverse of removalEdited by: sw2cam
do you by anychance know the bulb number. cause i''d like to replace mine with a blue bulb to match my blue theme[img]smileys/smiley2.gif[/img]
Originally Posted by RoyaL-Blue-Vue
do you by anychance know the bulb number. cause i''''d like to replace mine with a blue bulb to match my blue theme[img]smileys/smiley2.gif[/img]
| All times are GMT -5. The time now is 08:26 AM. |
