Alpha Centauri |
05-21-2015 03:19 PM |
Hi there Chawala, to answer your question: No cooler for standard/manual trans. They don't contain an oil pump, so no way to get the fluid to a cooler. Also, there is no heat build up in a standard transmission, like an automatic that has internal clutches and a torque converter. Most of the heat from an automatic is generated by the torque converter, no need for one in a manual trans as the clutch and flywheel convert the torque from the engine to the trans. The clutch and flywheel are external from the inner workings of the trans, and although they do generate heat, it's dissipated quickly by air circulation inside the bell housing from the rotation of the clutch and flywheel assembly.
