need help with stupid alarms system
Hi all, I'm new here and need some help. I have 2007 AWD Vue. I put in a new battery this morning and now the alarm sounds when I open a door and the ignition is locked out. How to fix it? Thanks in advance.
Aftermarket alarm?
Maybe the procedure is in the owners manual?
I thought I would post my solution to the problem described for anyone interested. after some experimentation, I disconnected the battery, opened the drivers door, inserted the key into the ignition and turn to the run position. Then I connected the battery and everything was fine. the alarm rest and life is good. But for some reason I could not post this solution as my user ID has been banned...forever. I had to create a new ID to sneak this update into the forum.
Thanks to all that replied to my request for help.
Did you figure that out on your own or was it actually in the owners manual or what?
thanks for getting back to us with the solution.
