-   -   Is my Manual Trans Failing? Knocking noise/link to video (https://www.saturnforum.com/forum/saturn-vue-24/my-manual-trans-failing-knocking-noise-link-video-13304/)
genistas17 Aug 13, 2024 11:46 AM
Hello, I had just started accelerating from a stop earlier today (in my 04 Vue 2.2 Manual) when I heard a clunk and the car jerked a little. After that it continues to drive and shift smoothly but with the addition of a repetitive clunking noise whenever the car is coasting (whether the clutch is in or out). It speeds up and slows down with the speed of the car.
I jacked up each side, put the car in neutral and spun each wheel. The video shows the sound I get when I spin the wheels. Does this sound like a failure in the transmission? Link to video is below. Please try to disregard the sound of a dust shield rubbing up against my warped brake disk. Thank you!
02 LW300 Aug 17, 2024 11:11 AM
Does it make that noise on both sides?
genistas17 Aug 19, 2024 06:47 AM
Hello, yes it does. I jacked up both sides individually and spun each wheel, and the sound is the same.
I purchased a new another car yesterday but I'm going to see if I can find a transmission for this and maybe get it back on the road soon. With 208k miles though I'm not sure it's worth it.
02 LW300 Aug 19, 2024 08:28 AM
Yes, it sounds like a new transmission would be the solution. It is up to you if it is worth the cost of repairs.
genistas17 Aug 19, 2024 08:33 AM
Thank you!
Rubehayseed Aug 20, 2024 07:54 AM
IF you replace the transmission, you might as well go ahead and put in a new clutch, pressure plate and throw out bearing. I'd take a good look at the flywheel too and if it's scored or burned, replace it too. That way it'll all be new and you can get a long time use out of again.
