Intermitent CKP error
Old May 11, 2025 | 12:08 PM
pic_az's Avatar
Default Intermitent CKP error
I got a code for the CKP about 2 months ago and replaced it and did a relearn with my scanner. I now get every couple of weeks the code again. Sorry, I just cleared it this morning and forgot to write it down. It appears to only happen during a start of the engine. Every once in awhile it will code as an engine misfire. Both of these clear themselves after a few more starts. The next time it codes, I will have the code. It's more annoying than anything else as I am thinking it could be something more serious so I have to check it. The last codes have been only those 2. I know I should have the code for you but I thought I would throw this out and see if anyonre has any ideas.
Joey
Old May 11, 2025 | 12:11 PM
pic_az's Avatar
I forgot to mention this is a 2006 Saturn Vue 2.2L.
Old May 11, 2025 | 03:44 PM
grcauto8453's Avatar
Get us the code.
Old May 13, 2025 | 12:51 PM
pic_az's Avatar
Looks like I jumped to quickly. The code is P0340. It is the Camshaft sensor and not the Crankshaft sensor. I will order one and replace.
Old May 13, 2025 | 01:01 PM
pic_az's Avatar
Back again. From what I am seeing, there is no Cam Position Sensor and they are using the ECM. Is that correct? I replaced the whole Coil Pack and ECM about 3 months ago. Yes, kind of when all this began, If the location is true, I am wondering if the ECM is bad. Any thoughts?
Old May 13, 2025 | 01:03 PM
pic_az's Avatar
Looks like I jumped to quickly. The code is P0340. It is the Camshaft sensor and not the Crankshaft sensor. It appears from what I am seeing that there is no Cam Position Sensor per se. It looks like they are using a connector on the ECM. I replaced the whole coil pack and ECM about 3 months ago. Now I am wondering if the ECM is bad.
ANy thoughts?
Old May 13, 2025 | 01:25 PM
pic_az's Avatar
I'm sorry, I said ECM but meant Ignition Control Module.
Old May 13, 2025 | 04:14 PM
What plugs do you have in there?
Old May 13, 2025 | 04:32 PM
pic_az's Avatar
I changed those plugs around 80K and now have 103K. I think they are NGK but I am not positive. I just replaced the ICM with my old one and the code cleared itself. I turned in the new one for a warranty replacement as it had 12 month warranty.
Old May 13, 2025 | 05:06 PM
Usually when problems show up after replacing old parts with new ones, one of the new parts is the issue. If you're buying crap from Autozone or Advance, STOP. I have worked for both in the past and most of the stuff they sell is substandard quality. I don't shop at either one unless I see a sale on Techron products. I try to buy online and if rockauto or the manufacturer is out of it, I'll try NAPA. O'Reilly is next to last with the other two mentioned as LAST RESORTS.
