-   -   High Idle at Neutral speed. (https://www.saturnforum.com/forum/saturn-vue-24/high-idle-neutral-speed-3125/)
Zenidyle Apr 3, 2009 01:21 AM
Hi all,
I am new guy in this forum. I have a issue and need help.
OK, first of all, my car is 2003 Saturn Vue I4, 5 speed manual tranny, 92xxx miles on it. I just replaced 2 oxygen sensors ( one for each upper and down tream ), 4 new NGK spark plugs , new K&N air filter. Car run and drive fine but only one thing happen last week that engine is running little high Idle at 1200 RPM whenever I am in the red-light with neutral speed or depressing clutch or it's at parking. It used to be at 700-750 RPM.
I don't feel good when it's at high idle. Anyone has ideas to help me out. Thanks a lot.
Zenidyle Apr 7, 2009 07:01 AM
Just let everybody know that I fixed it by replacing Temp air flow sensor. After I make sure all vacuum suppose to be good in the spec no leak
OceanArcher Apr 7, 2009 03:06 PM
It's always a pleasure to see a contributor think their problem through, and come up with the solution that puts them back on the street -- congratulations.
