gurgling coming from the gas tank
I have a 2008 Vue XR and I am hearing gurgling coming from the gas tank. It sounds like someone blowing air through a straw into a glass of water. My Vue is also taking a longer time to start. Could this be the fuel pump? |
Sound like it is sucking air and you are hearing it when it returns the air to the tank. So I would say a fuel pump cartridge should fix both problems. |
Originally Posted by 02 LW300
(Post 59793)
Originally Posted by jaf
(Post 59794)
thanks. I will check that out.
I looked on Rock Auto and 2008 Vue with any engine uses what I refer to as a cartridge. It comes with the plastic body and hoses and the top with the fuel line connections. |
(Post 59796)
I looked on Rock Auto and 2008 Vue with any engine uses what I refer to as a cartridge. It comes with the plastic body and hoses and the top with the fuel line connections. That is what I thought. Thanks for the clarification. I appreciate the help. |
