Gear oil question.
Hi there Gang!
Got a question sorta. Differential oil... The Books and a fair bit of the online world talks about GM versatrak "or compatible 75-90" etc. We have started using mobilube hd plus mg 75w in place of gear oil in most of our industrial and heavy truck applications., is there any specific reason why i couldnt use in in the Vue differentials/xfer case? Just a thought, another option close at hand would be an 85-140... that would quiet down the gears, and lets face it, the diff is the size of a grapefruit so its not like the difference would be that big. |
I would say that the “ compatible 75-90 would indicate yes” use what you prefer.
Originally Posted by 02 LW300
(Post 79614)
The front transfer case is a hypoid gear drive. No clutches. The rear diff has a clutch pack. Does that mean different oil specs? I just replaced my t-case and put in 75-90.
| All times are GMT -5. The time now is 06:55 AM. |
