fuel pump
I am going to change the fuel pump on my 2008 Vue XR. Is there an access point from inside the car, or do I need to drop the tank? Thanks
Don't have a service manual, but I doubt it.
Picking up a Chilton or Haynes manual will answer that question -- and many more down the line. |
No, there's no access hole. You'll have to drop the tank. If you think you may ever have to do it again, once the tank is out, you could always cut a hole for the next time. Please don't do this with the tank in place. If there are any gas fumes at all and you make a spark, it could be fatal.
