2008 VUE XE 4 cylinder No odometer and gauges plus key stuck in ignition
Old Feb 4, 2026 | 08:28 PM
08vuexe's Avatar
Default 2008 VUE XE 4 cylinder No odometer and gauges plus key stuck in ignition
08 vue with around 70 k miles and Im starting to lean toward potential bad bcm because I pulled some bcm codes, I did notice some corrosion and rusty bolts so I grabbed some electrical cleaner and wanted to clean the ground areas maybe grab some 80 grit sandpaper and sand it down too. I have no gauges or odometer and key gets stuck in ignition, Read this is a common problem with these. I will try on the ground with the fuses beneath the kick panel , any other ideas?
Old Feb 5, 2026 | 05:20 AM
Which codes were they (Bxxxx format please)
TigressK78
Nov 3, 2023 09:15 PM
Infernotamer
Sep 2, 2023 12:05 PM
Wargasm
Apr 11, 2018 11:49 PM
teenug
Sep 29, 2017 08:04 AM
rytomi
Nov 14, 2014 07:51 PM
