-   -   2008 Saturn Vue XE 2.4L Error Codes (https://www.saturnforum.com/forum/saturn-vue-24/2008-saturn-vue-xe-2-4l-error-codes-13487/)
02 LW300 Feb 6, 2026 07:26 PM
These wheel speed sensors are parts of the wheel hub assembly. The tone ring? Is inside the bearing assembly. I doubt your antilock brake problems are at the wheel ends. It is much more likely to be a module, the antilock is probably part of a traction control, roll stability control module. Your VUE is very similar to other GM models.
derf Feb 7, 2026 10:19 AM
The EBCM is known to be problematic on these vehicles. I did not want to rush to judgment without checking some simple stuff first if possible. This might confirm Andy's suspicions of a module issue.
TXSaturn Feb 7, 2026 11:00 AM
I've suspected electrical issue all along since codes come and go and one of the codes is C0899 Device Voltage Low even though alternator putting out 15V when running.
I assume the EBCM is not a cheap replacement. Thoughts on how to prove it is the problem?
Part number for replacement? Looking on RockAuto I cannot find EBCM, only BCM or ECM.
oldmarine Feb 7, 2026 07:38 PM
Part number from charm.li is 19153229. Part shows as available from GM Parts Giant ($220), AutoZone ($270), and multiple sellers on eBay starting at $500.
