2007 Saturn Vue Hub bearing assy
How do you get the hub bearing assy out? I have everything disconnected and it should come out with the slide hammer I am using but I do not dare over do it. Is there a trick to getting them out?
Thought they were pressed in.........and out.
You might need to wd40 them and let it set for a little bit I looked at a pic of the hub assembly it looks like you should have 4 or 5 bolts on the back side of them and they should come out
