2006 Saturn Vue with leaking sunroof
My Vue seems to have the left rear drain hose disconnected.
How do I drop the headliner to reattach the hose? Thanks CP |
?? Disconnected ?? -- unlikely, but not impossible.
More probable scenario --> plugged drain from crud. Run thin semi-flexible wire down the drain, or blow it free with the use of canned air ....... |
Leaking Sunroof
Thanks Ocean Archer.
How do I locate the drains? I can't even see them. (this could could be age related) I hope that I can open them rather than dropping the headliner I poured water in each corner and the left rear caused water to leak from the headliner to the rear post pillar and drip into the well. After removing the plastic cover and trying again, the water ran right out ot the headliner. We have had a fierce rain storm and the wheel well had nearly 3 gallons of water in it. Charlie |
| All times are GMT -5. The time now is 04:06 AM. |
