2004 Saturn Vue Stock Stereo Question
Can the 2004 Saturn Vue Stock Radio play burned audio CDR's? Thanks
The 95 SC2 could.
I don't see why not. Just don't put an adhesive label on it. It can screw up the weight distribution and make the disc wobble oh so slightly while spinning which messes up the focus on the lens after the light bounces off the disc. Even if you put the sticker on absolutely perfectly, it will eventually start to lift off and get caught in the slot where the disc goes in and out |
Thanks
Thank you for replying. I just got this 2004 Saturn Vue a few days ago coming from a 2003 Ford Focus. I was hoping the radio had an AUX jack but it don't. Then I figured I just burn my music to CDR and use that. But I just discovered those Amazon FM Bluetooth transmitters and was pretty happy there was an option for me to listen to my MP3's without having to upgrade the stock stereo. But yes! Thanks for letting me know about the cdr compatibility as I may still try that as well. Cheers!
If there is an AUX button on the face of the radio, there is probably an AUX jack on the back of the unit. Please post a picture of the radio you have.
| All times are GMT -5. The time now is 06:52 AM. |
