2004 Saturn Vue ABS Issue
I found the wiring going to the wheel sensor on the right front wheel of my 2004 Saturn Vue is damaged behind the disconnect for the sensor. Anyone have any idea where I can get a replacement wiring harness? Thanks
Tony |
junkyard............welcome
saturnparts.net
saturnparts.com |
Entire wiring harness, yes go to
saturnparts.net saturnparts.com |
While your at it stop in the new member area and introduce yourself. Would be a good idea to add a first name, location, and yr/model to your signature right after you complete your profile
A wrecking yard is the source for a wiring harness or as Derf indicated that can be purchased (apparently anyway I did not look) new. If you have any experience in electronic assembly repairs can be made to almost any harness with proper tools and some knowledge.
With out that though? All bets are off and changing an entire wire harness in an automotive application is something that I have done and do not recommend to some one who has no clue how to do it. |
