-   -   2002 VUE (https://www.saturnforum.com/forum/saturn-vue-24/2002-vue-1694/)
DANW Feb 8, 2008 02:28 PM
My wife car has an intermitted problem that will not let the motor start. IT will crank but the motor will not start. Motor is a V6. If the car set a bit maybe 5 minute. It will eventually start again. I have checked the fuel pressure one time when it would not start and it was around 50-60 PSI. You can hear the fuel pump running. I service engine light is on so this week end I will check the codes. Has any one else experience a similar problem? I am thinking the crank shaft sense but I want to be certain that is the problem. Sometimes it will go 4-5 days and run fine, other times 1-2 times a day. Any help will be appreciated. Thanks Edited by: sw2cam
DANW Feb 8, 2008 02:31 PM
The problem has never shut the engine down. IT happens only when you try and start the car, Other than that the car appears to run fine
Edited by: sw2cam
original007 Feb 8, 2008 08:19 PM
Most likely crank sensor
DANW Feb 29, 2008 09:01 AM
Replaced CPS last week and car is running great. Thanks
