2002 Saturn Vue
Swapped out VTI all wheel drive to a 5 speed front wheel drive.
Plugged selector switch from auto trans in to read park hoping to start fuel pump and starter. Everything works, except fuel puimp and starter. I'm missing something? Gattabout |
I have all the shop manuals for 2002 (Ebay). Looking for solution.
Gattaboiut |
Maybe you need to run the power to the switch on your clutch instead of neutral safety switch? I don't know, just guessing.
Originally Posted by gattabout
(Post 45958)
Plugged selector switch from auto trans in to read park hoping to start fuel pump and starter. Everything works, except fuel puimp and starter. I'm missing something? Gattabout Are you using an engine wiring harness from a manual equipped Vue? If not then know that they are wired different. You will need to use a Manual Vue wiring harness and manual vue ECM. Remove automatic transmission and old ECM from the engine because they will no longer work for the Manual transmission application. The clutch pedal which you had to install has a switch on it. Cut the small wire going to the starter a little way away from the starter and splice into each side of that with wire long enough to run to that switch. This will provide you with a neutral safety switch. |
2002 Vue tranny swap
Using 5 speed wiring harness and ECM. I have a security light on the dash which is on. Could this need cleared for fuel system to work? Need to know how?
Thanks, Gattabout |
ECM needs to be taught to recognize the vehicle. If you need to know how let me know.
Andy |
| All times are GMT -5. The time now is 05:24 AM. |
