2002 Saturn VUE
Old May 5, 2024 | 11:54 AM
vargas535455's Avatar
Default 2002 Saturn VUE
Wouldn't an intake leak make it run lean?
intake is new and gasket. Based on the answers I have too much fuel pressure or extra air in system. What should the fuel pressure be at on a 2002 VUE 2.2 liter. I don't hear any strange sounds on the engine or exhaust to indicate a crack.
Old May 5, 2024 | 04:15 PM
grcauto8453's Avatar
Brain fade. Wrong post.
Do we know what fuel pressure is? No sense doing anything until we get that done.
Old May 7, 2024 | 07:55 PM
I finally got my hands on a fuel pressure kit. I have 57 psi on fuel pressure.
Old May 7, 2024 | 08:17 PM
2.2 or 3.0 V6?
Old May 7, 2024 | 10:07 PM
2.2 liter
Old May 8, 2024 | 05:49 AM
Key on fuel pressure spec 50 to 60 so seems ok there
Old May 8, 2024 | 07:32 AM
I am going to try looking for air leaks. Finding options to try and locate.
Old May 8, 2024 | 08:17 AM
Your problem is under load. Not going to be a leak. You need to check fuel pressure under load. Power brake. Does it hold?
Old May 8, 2024 | 08:29 PM
I will get a fuel pressure kit tomorrow and test with hand break on.
Old May 9, 2024 | 12:24 PM
Testing under load. I put it in first gear with emergency brake on. Nothing happened car stays running. No pressure drop.
