04 VUE Tranny??
I own an '04 VUE AWD w/ 74K miles. Need to change tranny fluid. Should I hire a shop to "flush" it OR drain, change, drive 200 miles and redo. I assume you can NOT drain the torque converter...right??? THX in advance and Merry Christmas.
BTW: overheat light came on yesterday in the mountains while pulling a heavy load (1800 lbs). Stopped, cooled down, check fluid which was low. Added 1/2 quart. Definitely black NOT pink:(((((( |
UPdate on tranny:)
Z1 ATF has been replaced by DW1 according to EBay. Local shop wants $250 for flush. One shop highly suggested drain, drive, drain, refill. Considerably less expensive:))
I just changed the trans fluid in my VUE. It's very simple. You can have it done in 30 minutes. I bought the Z1 fluid at Chevy dealer for a lot cheaper than online. They carry the Honda trans fluid to service saturn customers.
Originally Posted by kzdcz3
(Post 42867)
What year do you have and is it the VTI (CVT) transmission? If it is the VTI do you have a dipstick? If you do not like I don't how did you add and check the oil level? Thanks, Andy |
Originally Posted by blaisa
(Post 42929)
Thanks, Andy |
I found my fill cap which is a large cap on top of the transmission which looks sort of like a smaller version of the engine oil fill cap. It required removal of the battery, battery box and the fuse/relay box to see and have proper access to it. As for a dipstick, no luck. I have the drivetrain out of the vehicle for a 5 speed swap and there isn't any dipstick.
Thanks, Andy |
