03 saturn vue v6 stalls will not start till cools down
derf, iam back, I got good news , got the new cks sensor put in and that was a real problem. got it out with a litte work , but the problem was it would not go into the hole, (after market) in the case where the two set and o-ring was. didnt want to break it , it was that tight. took the o-ring off and sanded the two ridges on each side and took the sharp corner off and it shiped into the hole. great. change the fuel pump relay . and air filter. have to tell you it runs great again, no stalling my 03 vue is backi did replace cps and cks, and fuel relay.and will be putting a new inline filter in to. i do think it was the cks sensor with all my heart. now on to the new thing on my list and try to take care of menbership by the 17 so i can tell you the things i got planed for my ride thank for the input
Lemme guess: 1st CKP (crank pos sensor) was from Autozone . Probably your only problem.
Cheap aftermarket crap costs more money in the end after changing 5 other parts you'd never touch if the the first replacement CKP was not defective.
(not scolding YOU-- just making a general comment).
