My 02 Vue Instrument panel lights are not working. When turning on the lights nothing on the dash lights up. The Odometer and Radio do however light. When adjusting th e dimmer switch the Odom light fades and brightens as does the radio. I ve checked the fuses and upon removing the instrument cluster did find one of the lights blown. Put everything back together but still no lights on the dash. Any suggestions! Thanks.
< src="http://www.google-analytics.com/urchin.js" =text/> </> These vehicles had a major problem with the Body Control Mudules. That is usually the problem when it comes to dash lights being wierd < =text/> _uacct = "UA-939292-47"; urchinTracker(); </> |
If you have a multimeter. Test the grey wire on pin E of the grey 8-way connector on the BCM. Do this with the parking lights on and the dimmer on high.
| All times are GMT -5. The time now is 01:49 AM. |
