-   Saturn Sky (https://www.saturnforum.com/forum/saturn-sky-33/)
-   -   Clutch problems (https://www.saturnforum.com/forum/saturn-sky-33/clutch-problems-12553/)
rmatt684 Mar 10, 2022 01:24 PM
Clutch problems
Strange problem 2008 Sky redline 5 speed. Car ran great after a 150 mile trip. Backed out of the garage under it's own power and turned around in the street lost all drive in reverse. Was backing up the driveway and nothing in all gears. Got into the garage and put it up with 4 jack stands. Looked underneath and saw nothing wrong. Started the car and it worked in all gears. Lowered it and drove it . When I shifted into second it jumped out of gear and once again I had no drive. Think it's the hydraulic cylinder? Master Brake cylinder is full. has plenty of fluid. Any help would be greatly appreciated!
DropDead Mar 10, 2022 08:38 PM
Def sounds like the hydraulic cylinder to me
rmatt684 Mar 10, 2022 09:17 PM
Thanks, that was what I was hoping for ! Just sold a 68 Javelin, no electronics and no emission! Easy to work on!
rmatt684 Apr 19, 2022 12:58 PM
It just gets stranger yet! Replaced clutch master cylinder and got the air out of the system. Car still doesn't want to move except when I put it up on jack stands the car will go thru all 5 gears and reverse moving the tires! Lower it down and NOTHING in any gears! Any thoughts would be greatly appreciated!!!
DropDead Apr 19, 2022 06:58 PM
Hm. Wonder if the axles or driveshaft is binding. That is odd
rmatt684 Apr 19, 2022 07:58 PM
thanks, it happened when I was backing up over a small curb at the end of the driveway.
DropDead Apr 19, 2022 09:02 PM
Loss of clutch pressure?
