| krazy Dan |
Jun 10, 2013 07:29 PM |
Yes! Another Belt Noise...
Here I go again. Im about 90% sure I know what the problem is this time but it seems like every time i turn around I am having some sort of problem with my drive belt or its accessories. This just started the other day. With the A/C on when i come to a stop and the RPMs drop it makes a heinous squeeling sound then stops as i accelerate or rev the car to approx 3k RPM. Then the process repeats itself as I start to slow again. Also does it if i turn the ac on when it hasn't been on. I'm pretty sure its the belt tensioner since its about the only pulley that has not been replaced recently other then Crank Shaft pulley. AC comp, idler pulley brand new. Alt & power steering brand new-ish (def not old enough to go bad yet). Belt is brand new. So I think its slipping a bit under load because the tensioner is going. Also I've noticed recently that all accessories dont seem to be working up to par. Headlights dim breifly when the RPMs drop under idle at a stop light, occasionaly the power steering feels stiff and AC sometimes works great other times not so great.
So I'm thinking all this stuff is related to the tensioner. What do you guys think? I kind of hate to replace it because I read all the horror stories about putting aftermarket tensioners on and the belt not fitting and causing all kinds of other problems.
Thanks, Danny
