No, not the aftermarket harness for a CD player, I'm talking about the harness that goes from fusebox to fusebox. I ended up having to replace that entire section of harness. Luckilly, I found a place here in Rancho Cordova, M&S Recycling, which specializes in Mits and Saturns, who pulled the entire harness for me for 150. Now, I am a bit stuck. If you look at where the wiring comes in to the fusebox from the firewall, there is a rubber gromet there that I can't seem to pop out to pull the harness down. I know its probably something simple, but after all I've done to this car in the past 2 months, I'm lacking in common sense. Help? |
