where can i get the plastic clips that hold the window to regulator?
I've a 98 SL2 that the back window was having issues. Took it apart and found the plastic clip that hold the ball of the window regulator into the window track is broken. the nearest Saturn dealer is 1 1/2 hours away. Is there somewhere else I can buy this part or order it online?
thanks |
junk yards
I would make the drive to the dealership, I just replaced mine on the back window and a junk yard will make you buy the whole regulator. I paid 6 dollars at my saturn dealer.
When you do put it in make sure you have the flat side facing the back of the slide. And it helps a lot if you soak the part in boiling water for a few minutes to make it softer and able to pop right on to the regulator arm. P.S. did you ask the dealership to ship it? |
