-   -   valve cover hose (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/valve-cover-hose-1261/)
5inchdrop Aug 9, 2007 11:05 PM
what does the hose from the valve cover to the intake manifold do? can i block both sides of this off with breathers?
sw2cam Aug 10, 2007 09:13 PM
It's part of the PCV system, and yes you can.
5inchdrop Sep 14, 2007 06:21 PM
i put breathers on both ends and the car was reving at 2500 rpm. so i guess u cant.
sw2cam Sep 14, 2007 07:36 PM
I guess you have something other going on. I've had them on mine for years
Low Saturn Sep 14, 2007 08:04 PM
No, you cant.
5inchdrop said in his post that its the tube going from the cam cover to the intake MANIFOLD, not the intake TUBE. Removing the tube from the PCV line will cause a massive vacuum leak. The other tube that connects to the intake tube is not under vacuum and can be replaced with a breather.
sw2cam Sep 14, 2007 10:15 PM
sorry.............mybad pictured the wrong picture, but now he knows you can't let manafold vacuum go to the atmosphere
5inchdrop Sep 16, 2007 02:12 PM
gotcha. thanx guys.
